Solid Plus is an Industrial Forklift Tyre replacement service company operating throughout Australia. Solid Plus supplies & fits tyres from Continental, Watts, Advance, Armour and Double Coin to cater for all applications, budgets and specific uses of forklifts and other Industrial and materials handling machinery.
Continental has developed an innovative forklift tyre & wheel combination solution called CS Easy which has been launched progressively over the past 2 years.
Solid Super-Elastic tyres are robust, durable and require minimal servicing. They save energy and are exceptionally shock and wear resistant . That's why, for many applications, Super-Elastic tyres are the first choice - and in particular Continental's premium CSE range. Now Continental's engineers have developed a new range of tyres that will revolutionise Super-Elastic tyres forever.
Introducing Continental's CSEasy - quick, easy, flexible fitment.
CSEasy is the first Super-Elastic tyre that requires no press, specialist technician or equipment.
Tyres can be fitted in situ, as soon as the tyre breakdown occurs, ensuring the forklift is back in full operation in minutes.
Press-less fit to rimThe key to CSEasy is the innovative adapter which is placed between the tyre and rim.
Thanks to the adapter's conical shape, the tyre is already in position and is simply screwed onto the rim using a torque wrench - making the press redundant.
CSEasy does itTwo hands and a torque wrench are all you need to fit the new CSEasy tyre on any Lemmerz type rim.
CONTINENTAL CS-EASY |
Rim SizeClass | Tyres4U Code | Tyre Size | Description | Tread Pattern |
8" | 16068 | 180/70x8 18/7-8 | Solid CS Easy Set | SC 15 |
9" | 16349 | 600-9 | Solid CS Easy Set | SC 15 |
| 16620 | 200/75-9 21x8-9 | Solid CS Easy Set | SC 15 |
10" | 17090 | 225/75-10 23x9-10 | Solid CS Easy Set | SC 15 |
12" | 17586 | 700-12 | Solid CS Easy Set | SC 15 |
For further information on Continental CS Easy in Australia contact:
Solid PlusFrecall 1800 002 150
FreeFax: 1800 788 988
Web:
www.solidplus.com.au or
Email:
henk@solidplus.com.auClick here to visit the Solid Plus Shopfront
