Meclift Variable Reach Truck ML 5012R
- 13 Mar 2008 ( #351 )
Oy Meclift Ltd, a Finnish manufacturer of Variable Reach Trucks and Side Reach Stackers, launches its Variable Reach Truck ML 5012R for heavy lift applications. The first truck is delivered to an Italian customer for in-ship stone handling.
The Variable Reach Truck ML 5012R has a lifting capacity of 50 tonnes at a load center of 1.2 meters. It is characterized by a reach feature which enables it to handle heavy loads from locations impossible for the straight-masted trucks. The compact truck is capable of operating in confined space indoors or outdoors. Thanks to its telescopic twin booms, the truck has a relatively low overall height. Combined with a toplift container spreader it could be used for on-board ro-ro activities. The direct hydraulic lifting is also simpler to maintain.
The horizontal telescopic twin boom configuration and hydraulically movable cabin design offer excellent visibility and comfort for the driver. The truck is equipped with electrically controlled, low emission Volvo engine, ZF transmission and electrically controlled load sensing hydraulics and variable displacement pumps, combined with CanBus technology for reliable operation.
The machine has a maximum lift height of 6.55 m with forks and outreach of 2.25 m. With the machine length of 7.7 m (without forks), width of 3.8 m and turning radius 7 m it is the most compact lift truck on the market in its lifting capacity range.
TECHNICAL DATA
  1  Manufacturer        Oy MECLIFT Ltd
  2  Type        ML5012R
  3  Lift capacity/ load center / height     kg/mm/mm  50000/1200/5000
  4  Power source        Water cooled diesel engine
  5  Tyres  front / rear     4*18.00-25 / 2*18.00-25
  6  Lift height     mm  6550
  7  Reach     mm  2250
  8  Length to the front face of the forks     mm  7725
  9  Width     mm  3800
  10  Height     mm  3730
  11  Turning radius     mm  7030
  12  Driving speed  forward/reverse  km/h  26
  13  Lifting speed   loaded / unloaded  m/s  0.2 / 0.2
  14  Drawbar pull     kN  200
  15  Gradeability   loaded / unloaded  %  15/30
  16  Weight     kg  59000
  17  Axle weight loaded / unloaded   -front  kg  103000/27000
        -rear  kg  6000/32000
  18  Wheelbase     mm  5180
  19  Ground clearance     mm  330/260 mm
  20  Brakes  -service brake     hydraulic wet disc
  21     -parking/emergency brake     Spring powered disc
  22  Voltage     V  2x12V-110Ah
  23  Engine  -model     Volvo TAD952 VE
       -power rating ISO 2534  kW  252
        -rpm at rated power     1900
        -peak torque  Nm  1700
  24  Transmission, power shift with torque converter        Dana Spicer TE32
  25  Drive axle        Axletech PRC7534W4H
  26  Hydraulic system: Electrically controlled proportional load sensing system. Two double pumps are mounted to the transmission.
  27  Cabin - furnished with air conditioning, radio and instruments
     - hydraulically movable vertically
  28  Steering - fully hydraulic, double rod steering cylinder
  29  Lift carriage with hydraulic fork positioning
  30  Forks 2400 mm in length
  31  Automatic stability control, electronic weighing of the rear axle
Further information:
Oy Meclift Ltd
Veijo Miihkinen
Tel. +358 20 743 1120
Fax +358 20 743 1121
www.meclift.fi
Click here to visit the Oy Meclift Ltd ShopFront
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
