WWP’s NEW WP60-13
- 28 Sep 2006 ( #279 )
Special features of WP60-13:
1. "Creep" switch option
2. 16 species are provided
3. Maintenance free battery
4. Easy charging plug - (option)
5. Customised is available
6. Specially designed for narrow space, mini and maneuverable
7. Minimum lowered height of forks can be adjusted
8. Very small turning radius, especially for very narrow aisle and inside closed trailers
9. Easy entry forks, single or double load wheel option
10. CE certificate, ISO9001:2000 factory
Common features:
1. Intelligent drive control:
Driving system gives smooth, steeples acceleration and infinitely variable speed control, and it utilizes regenerative braking which reduces heat of motor and increase power of battery. The anti-rollback system delivers maximum power when required for uphill starts on loading ramps. The system also provides improved speed control during travel on uphill or downhill gradients. Drive performance can be adjusted by using programmer unit.
2. Safety design:
Limit switch automatically cuts off pump operations when the lift cylinder reaches the end of its travel. Overload valve is a safety relief, to keep the hydraulics from lifting over capacity of the unit. Heavy-duty stabilizing caster wheels to provide excellent stability and reducing product damage even when making sharp turns. Emergency stop button will cut the power supply and make immediately stop.
3. Ergonomic and strong handle:
Heavy-duty control arm with ergonomic handle and effort-free controls. Handle can turn of 180 degree's angle to ensure excellent maneuverability in narrow space.
4. High accurate and durability:
Piston type lift cylinder, has a hard chrome plated ram for long lift. All shafts are heat treated with grease injected in all pivot points, makes lasting longer life. The compact chassis is thick and heavy-duty providing more strength and longer life. Float-in drive unit reduce hard vibration from floor, which makes drive motor and gear box to have longer working life. All pivot hole machined by CNC machine after welding, which makes all lifting and moving at a high accurate and smooth.
Specifications Sheet
Contact:
Phone:
+86 574 8831 0963
Email: tarra@wwp-wwp.com
Link to WWP website: www.wwp-wwp.com
