Quick transport of long material through narrow aisles
- 23 Feb 2006 ( #248 )
Compact fourway side loader for loads up to 3,000 kg improves the storage capability and reduces costs. An outstanding feature of the new Hubtex series 3040 side loaders is the possibility of using them in three different ways: as fourway narrow aisle-side loader, as side loader for transporting long loads or as conventional front loader for pallets and block stacking up to 3000 kg. With these characteristic features, this side loader is for example ideally suited for handling timber, building materials etc...
The side loaders are available with diesel or gas drive, and can quickly transport long material through narrow gates and aisles in lengthwise drive. In crosswise drive, the series 3040 side loaders are used as conventional front loaders. Circle drive allows fast turning of the truck. The mobility of the series 3040 side loaders allows you to save up to 50 percent of valuable floor space. The permanent hydrostatic all-wheel drive of the 3040 series ensures optimal traction, also on inclined grounds, even in winter. Further outstanding characteristics of the 3040 series are fast steering and lifting movements and high driving speed.
Elastic tyres make the series 3040 side loaders suitable for indoor as well as outdoor applica-tions, even on semi-solid grounds. The standard features of the series 3040 side loaders include a 1200 mm or 1400 mm fork length, a +5/-3 degree mast inclination and a comfortable, ergonomic driver's cabin with very good all round-view. A long-load fork carrier, telescopic forks, as well as rack guiding rollers for the use in a rail mounted narrow aisle are optionally available. For outdoor use, screen wipers, working headlamps, cabin heater and cabin door are optionally available.
The side loaders are available with diesel or gas drive, and can quickly transport long material through narrow gates and aisles in lengthwise drive...
Further advantages include:
* Continuously operator-controllable proportional valve technology, working without jerks, for all lift mast functions.
* Operation of all lift mast functions via joystick; there is no need to change to another single operating lever.
* Pre-selection of direction of motion by means of a separate cross lever.
* Extended steering angle in lengthwise direction of motion for extreme manoeuvrability in narrow aisles.
We are pleased to be at your disposal for any further questions:
The new Hubtex series 3040 side loader is the possibility of using them in three different ways: as fourway narrow aisle-side loader, as side loader for transporting long loads or as conventional front loader for pallets and block stacking up to 3000 kg...
Hubtex Maschinenbau GmbH & Co. KG
Lars Beuel
Industriepark West,
Werner-von-Siemens-Strasse 8.
D-36041, Fulda.
Ph.: +49 661 838 2223
Fax: +49 661 838 2120
E-mail: lars.beuel@hubtex.com
Website: www.hubtex.com
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
